2005 4.3 running hot and loud
Ds0610
Hey guys, I've tried to search as much as I can but I have a 2005 4.3 that I replaced the impellar last year after that I had a leak in the water displacement valve and replaced it. Now my issue is that it is running hot (180-190) and seems louder than it did last year there is plenty of water coming out the exhaust when I run it on a hose any help would be greatly appreciated!
Bt Doctur
if running hot you always start with the impeller first, drive should be a GEN II so worn/missing O rings in the connector guide tube.
Bad T-stat, clogged manifolds/elbows
Ds0610
My concern with trying the impellar is having to tear apart the lower unit and I'm not sure it addresses the louder running. Plus it was replaced less than 5 hours of run time ago
tpenfield
A 454 running on the muffs is sweet music :D
I would check for blockages in the cooling system. Maybe the remains of a previous impeller are located somewhere inside the engine's cooling passages. Less water flow means louder engine.
