2005 30hp 4stroke Tohatsu problem
longhorn daddy
Ok guys /gal im new to this site so please bear with me.
I have a 2005 30h 4stroke tahatsu motor .It will crank up and idle just fine but when i put it in gear it will die out.I have hooked it up to a waterhose and it will go in gear and keep running but when i put in the water it dies.Any help will be appreciated.Thanks
Sea Rider
Re: 2005 30hp 4stroke tahatsu priblem
Welcome to the forums,
If carb & fuel pump are inmaculate clean, have not played with mixture screw, seems idle rpm is bit low, place a induction tach and check once on water with warmed up engine, idle speed should be around 850 rpm, if not counting with a tach, adjust idle rpm screw CC untill engines does not die when placed at gear.
Happy Boating
pvanv
Sounds like you are running lean, or have a similar problem.
Year is unimportant; Model is critical. I'm assuming you have a Tohatsu MFS30A, right? That would have 3 carbs.
If so, clean all 3 carbs properly, in real carb dip, as per standard shop procedure. In the future, always run the carbs dry at the end of each and every day, to reduce varnish buildup in the carbs.
If you have a fuel-injected MFS30B, get to a dealer, and have him diagnose the motor, with the aid of the onboard diagnostics.
longhorn daddy
I live outside the Houston Texas area and i was wondering what is ( real carb dip) and where can i buy it ?
pvanv
Carb dip is sold in 1- and 5-gallon cans. Available at most good auto parts houses, and sometimes even at wal-mart. The 1-gallon cans (from Berryman's or Gunk, etc.), usually come with a basket to hold the parts during submersion. CRC Tyme also works very well, but... comes in a rectangular 1-gallon can, so you would need your own basket and/or can for the bath.
Procedure is to do a thorough, complete disassembly, including jets and emulsion tube nozzles, then,
A 4-hour bath to softem the organic varnishing, then,
A complete spray-out with generic carb spray, then,
Careful reassembly, paying special attention to float height.
