2005 25hp mercury elh will not start
JasonMayo
Boat sat for seven years or so then I received it for free. Put in new fuel, spark plugs, fuel lines but doesn't appear to be getting spark to the spark plugs. Not sure where to go next without knowing what resistance is supposed to be on the stator or how to check trigger.
flyingscott
Need a serial #. If it is a mercury built motor look to see if it has a tether switch. The switch should be a simple toggle make sure it is on.
JasonMayo
Serial# 1B165889. The switch is on. I have disconnected both the kill switches tip try to rule that out.
