2003 Yamaha 250 VMAX 0S66 water pressure
sammie4516
Water pressure with this motor starts out at around 28 to 30#,s drops to below 4# when RPM gets to about 5800. It runs for about a half mile then shuts down. As long as the RPM is at 5400 or 5500 the pressure stays around 12 to 15#'s. Flushed everything with no change. Changed the water pump with no change. Had a 4 blade prop on it switched to a 3 blade with no change. Any help would be appreciated.
99yam40
water pump sucking air or exhaust would be my thoughts
have you changed anything up on this set up lately?
has this rig ran fine before
sammie4516
Changed nothing. Just had a new water pump installed last week. Don't understand why it pumps fine at 5400 RPM but at 5800 it his to less than 4#'s.
