2003 DF 25 Will not idle
markhockin
I have a 2003 DF 25 that was running great and then started missing and stalling when the choke is removed or the throttle is decreased. I have changed oil, plugs, new fuel filter, hose, tank, sea foamed the engine. I have removed the jets on the outside of the carbs and blown them out and re installed them. Is this a low speed jet problem and where are they located on the carbs? The motor runs great at WOT but as soon as you slow down starts bucking and missing and if you slow down suddenly it just stalls and will not start without 2/3 choke and almost full throttle position.
Help please. This is my first four stroke and I hate it.
99yam40
Re: 2003 DF 25 Will not idle
Yes the carbs need to be pulled and cleaned and then readjusted properly
markhockin
Thanks for the advice. I will have to find a dealer I do not have the time for this and can not afford to risk dropping anything or losing a part.
