2003 225 DI No Oil Alarm
jtecker
This past weekend I got the "No Oil" alarm on my 2003 Direct Injection. Based on various online forums first attempt at fixing was to replace the oil pressure sensor as that seems to be the most common cause of a potential false no oil alarm. Picked up the sensor from my local Evinrude dealer. Replaced it, following all instructions for purging air from the lines and sensor. Did not fix. Checked all other connections for potential air leaks and can't find any. I also noticed that when I pinched off the oil return line for several 30 second intervals the engine does NOT smoke. Called my local dealer who said based on my symptons and having already replaced the sensor they are virtually certain the oil injector & manifold assembly has failed. I am inclined to agree with them. I'm sure they'll plug it in to confirm the error codes but before I drop $1,000 plus on this 12 year old motor I wanted to post here to get some other opinions. Anyone experienced in the DI's or even Etec's who can comment? Thanks in advance for any and all advice. I might add that aside from this issue the engine runs flawlessly.
