2002 Nissan NSF6A powerhead removal
the hodge
Hello, I have a 2002 Nissan NSF6A with a bent lower cover. I see that there is/was another poster here with the same problem but the thread is old and was never resolved. Questions are... does the lower unit need to be removed to remove the powerhead? Is there another way to remove/replace the lower cover? Should I just take it to a service tech?
Thanks,
the hodge
Sea Rider
Welcome to Iboats,
To remove power head from pan, need to free throttle cable from carb and remove bolts located under pan. Once out, wiggle power head front and rear while pulling upwards, should come loose fast. Probably will need a new base gasket if found severely burnt.
Happy Boating
the hodge
alrighty, almost ready to do this job, a few more questions.... do I use a gasket glue/sealant? and to what torque do I tighten bolts?
pvanv
Check in your Factory service manual (don't bother with aftermarket manuals). No sealant needed.
