0T591093 - 200XL EFI – 2002
Engine is not running on cylinders 2 4 6
Hot spark is present on all cylinders
Fuel pressure is at 42 lbs.
Ohm test of each injector passes
Wire test between injector harness and PCM passes
Swapped PCM with sister engine, problem remains
Cylinder drop test with MCDS shows these cylinders unresponsive
Swapped injectors from 1,3,5 with 2,4,6 and problem remains on cylinders 2,4,6
Compression is 115 lbs.
TPI voltage is correct and functioning
The injector plugs and the injector harness plug were all very wet with oil internally. This was cleaned and dried thoroughly, but had no effect. also disconnected the engine from the vessel and hooked it up externally and with external fuel supply . same issue
