2002 mercury 60elpto
wallydog2
I'm looking for a water impeller and lower unit seal kit when I search the serial it comes up with a jet pump 0t572116 is the serial 1060412zd is the model any help is appreciated
Fun Times
Hi and welcome to iboats.
Before ordering either kit, you are going to need to try and locate your gear ratio as there are a few different water and gear housing seal kit part numbers available when searching for the repair kits. Be sure to look at the serial number range as yours will be either in the Gear Housing, Driveshaft 2.31:1 0T622484/ 0P222544 and Below serial number range. http://www.crowleymarine.com/mercury...cfm?mdl=9XTKNC
Or if you have the 1.64:1 ratio then your kit part number will also be found near/at the bottom of the following link just like it can be found near the bottom in the above link above. Gear Housing, Driveshaft 1.64:1 Gear Raito. http://www.crowleymarine.com/mercury...cfm?mdl=9XTKNC
Just for reference, Here's a similar recent topic that covered the same situation as you may be in,
http://forums.iboats.com/forum/engin...6#post10123346
