2002 Merc. 5.0 running lean
Boat loving AMT
So I need some help please. I have a 2002 Mercruiser 5.0 MPI S/N-0M331599. A little history; I purchased the boat used from a private seller in 2015. Mercury service bulletin no.2003-06 was my first issue right off the bat. Somehow Wonderland Marine managed the impossible and was able to R/R the ECM under recall. Previous owner tried and failed twice to get it covered. Now I am wondering if the new ECM is the root cause of my lean issue or if Wonderland Marine had one laying around that was corrupted or the wrong one for my engine S/N? The boat ran great up until the fall of last year when I noticed a fluctuation of power above 1300-1500 range that accompanied what seemed to be a misfire, popping or pre-detonation. I figured it was bad gas. It was the end of the season so I drained the tank down as far as I could and used an external tank to winterize after changing the water separator. This spring I decided to move to 100% zero Ethanol fuel 93% octane. I filled up. The problem from last fall was still present. Not only that but after a few minutes of running close to full throttle the engine shut down. Had a hard time keeping it running and after less than 2 min of running I got an alarm and the boat seemed to go into limp mode. I broke down and took it into the dealer where it was discovered Cyl. 5 & 7 were at 0 compression with cracks in the pistons and on Cly #1 at 120 PSI (the lowest still reading) and the piston appearing acid washed. Cyl #8 was 180 PSI. Didn't remove the head to inspect Cyl 2-8 but a borescope showed similar appearances to #1 in Cyl 4 & 6. So I R/R'd the long block and now I am breaking in a new Motor. Long story short, I fixed the problem but still have a cause. The motor is running Lean. I haven't even began to advance past 1800 RPM's in fear of repeating the damage. At R/R I also r/r'd Fuel Injectors, Cap/Rotor, Water pump and impeller. During troubleshooting yesterday, I returned the original Fuel Injectors back to the motor just to eliminate the new ones from the equation. No improvement. Spark plugs indicate a lean engine. Note all sparkplugs removed from the damaged engine looked fine with exception of 5 & 7 which the electrodes were melted. So I need help getting this problem under control before I damage another motor. Please help!! All indications, fluid levels appear good and no alarms have been present. New engine has aprox. 1 hr 40 min. first hour of break-in was performed on land with flush muff. The 40 min was on water on and off 5 different times. Fuel Pressure is 34-38 PSI, I also ran with a remote fresh fuel supply and a new water separator/fuel filter with no improvement.
Jmunk
If it's certain cylinders running lean might be a bad injector driver in the computer. A noid light might be helpful.
I would have to confirm, however i believe fuel pressure should be 43psi per manual 31
That could be your problem
Boat loving AMT
The book I have which is a SELOC calls for anything over 25 psi good. That's at least what I have found so far. The reason I question that number is because it doesn't give me a specific RPM to take a reading at. Just at the turn of the key and at idle.
seloc manuals are not worth the paper they are printed on and are considered to be knee pads. neither are Clymer or haynes
here is the link to manual 31 http://boatinfo.no/lib/mercruiser/manuals/mercruiser31.html
Page 5A-2 (419 our of 638) lists fuel pressure as 43psi.
your running lean because your not pushing enough fuel. most likely an inlet restriction, maybe at the anti-siphon valve.
alldodge
Howdy
SB 2003-06 (shift interrupter circuit to ECM) would have no effect on your current issue. Don't know if the incorrect module was installed, would need to part number off the ECM to determine.
Currently Scott is on the right path about your fuel pressure should be 43 psi at 1800 rpm and shouldn't change much as rpm increases
Edit: Merc also installed a boost pump later in the model year to help with vapor lock and to help HP pump
