2002 40hp Johnson 2 stroke Jet power problems
TD55
This motor ran fine for a long time and then one day on the water at full throttle it started to run like half power. Now every time I try it the motor comes up to full throttle and seems to be running fine but then after like 3 seconds it cuts to half power. I changed plugs and did not fix it. I have replaced the tank and all lines and fuel connections still did not fix. I then rebuilt the fuel pump and still the same thing. I haven't tore the carbs apart yet. I read somewhere that the problem might be the coil. Anybody have any ideas of what else could be the problem
Honorary Supreme Mariner
Trouble shooting can be done, but most folks install a new powerpack.------That usually fixes them.
TD55
by powerpack do you mean new coil or does the powerpack encompass the coil plus other parts
Powerpack is NOT the coils.----------It is the unit that feeds into the coils via the orange /green amd orange/ blue wires.
fhhuber
A few seconds fine then low power... repeatable...
Could be the power pack
Could be something interfering with fuel flow.
A fuel flow issue could mean needing to clean the carb and put in a kit of new gaskets and the little float valve.
jakedaawg
If no alarms are sounding I would agree withe racer. Normally I would not suggest throwing parts w/out a diagnosis but this is classic powerpack.
TD55
Folks thanks for the help. I purchased a new OEM powerpack and replaced it. This did not fix the problem. Could I have a bad ignition coil. Or is it a fuel issue. What about timing? The motor still does the same thing everytime. Comes up to full rpm for 2-3 seconds and cuts out to like half power. I am new to boating and just don't know the troubleshooting. Thanks in advance
ondarvr
Normally you would look at coils before power packs. Check and see which cylinder is having the problem, pull a plug wire off and see what happens. It will normally run on one cylinder, it will just be low on power. Then pull the other plug wire and see if it will run. If it runs on one and not the other, then switch coils and see if the problem follows the coil.
Cleaning the carb never hurts, so you could do that too. Both are free and will help target the actual problem.
