2001 Tracker Crappie Pro 175 Wiring help?
aluislugo
Hello forum. I am new to the board and I need some help. I recently took out my panel switches and covered it with carbon fiber vinyl material. It looks really good now, however in putting back the wires I now have a problem with switches 4 & 5 (Aft Aerator Man & Bilge). The Bilge #5 will not turn on by itself unless I turn on the Aft Aerator #4. Somehow I must have crossed wires and now I can't figure out how to fix it. The Bilge switch only has 3 connectors in the back and the Aft Aerator has 5 connections on the back. I remember seeing that they both share a red wire. Anyway does anyone know what might be wrong? Or maybe you have this boat and can tell me where your wires go to each switch. Thanks for any assistance I might recieve.
PS. I don't have pics but I can provide over the weekend.
Re: 2001 Tracker Crappie Pro 175 Wiring help?
the shared red goes to the middle terminal you have it on the wrong terminal (guess) on switch #4
sotubre
You can put Tracker Procrappie Wiring Code in address bar and get the Color codes for Tracker Boats and motors.May help. Charles
sotubre
I'm having the same problem I took the wires off with out making a pic and could not get them right (old age) I found the codes but have to get back to the lake house to find out if th e codes will help. Had to get 10 new 5a spade fuses. The fuse box had 8 5a fuses.
aluislugo
