2001 Suzuki DF 40 Engine over charging help
pschiel
I just replaced the Rectifier and Regulator and now my volt meter is reading 16 volts which is too high. If the battery charging coil/stator is bad would it cause this to happen? Please help!
99yam40
Not sure about Suzukis, but Yamahas need a good ground to shunt off the excess voltage to ground to keep in under control.
might look at all connections
