2001 MonArk king 170
Calebp603
I have run into the issue of my front live well return line is crack and or the fitting on the front tank is cracked this with the boat in the water and water running into the return line it leaks a decent bit. Thus leading to flooding in the bilge I want to change the fitting and line all the way from the front to the back but I can not figure out how to get the front deck and tank out if anyone can help me that would be great I want to get it back to fishing this summer as its been off the water for twelve years and was put back on the water later this past season. With the 500GPH Bilge pump running boat would have about a foot of water in the bilge leading to listing to one side this pump is being upgraded to a 1000 GPH this winter. Any help would be greatly appreciated with the outlet on the back of the boat plugged with a bilge plug no water comes in I know it's from the return because I filled the bottom of the Livewell with water and watched the bilge fill.
Thank you,
Caleb
