2001 mercury optimax 200
Mlivoti
Just installed with 240 engine hours on 20' gw. Engine runs all the way to wot on earmuffs with no issues. Under load in water it won't go past 1600 rpm without stuttering. Have to throttle back and engine runs fine in idle. Can't get on plane. Engine warning light on smartcraft has continous beep.
Replaced all filters, cleaned fuel water separator. Replaced low pressure fuel pump. Tested air pressure. Tested engine on an auxiliary fuel tank with fresh gas same issue. New waterpump, waterflow is warm not overheating. Any ideas?
Faztbullet
That's a good way to do a quick disassembly in the driveway:nono:......Did you prime the oil system?????
Mlivoti
Engine was repowered in a shop and tested there. I assume oil system was primed when they tested but I'll double check. Could that cause this issue?
Faztbullet
yes as no load on motor, it will rev to WOT on 3 cylinders with no load
