shifted to reverse and went full throttle - could not shift back to neutral - took apart and stumpedParts diag shows shift cam (#38 diag 1) which shift rod moves up / down - shift cam has 3 steps for fwd / N / rev and as it moves up and down it looks like it should push cam follower (#52 diag 2) in and out which moves clutch to f/n/r - in other words shift rod moves down, shift cam steps move down which pushes cam follower in which pushes clutch in - That's how I think it should work
In my case the cam follower is attached or stuck on? the shift cam - see pics - when I move the shift rod down it only moves a 1/4 inch up down because cam follower is attached to shift cam and follower hits side of case
I can't figure out how or why why shift follower is attached to shift cam - any help or ideas appreciated
