2001 Mercruiser 5.0 EFI low RPM, low speed, slight vibration
OhioKyle
Hello all,
I have a 2001 Chaparral 196 ssi (19.6 feet) with a Mercruiser 5.0 EFI on an Alpha 1 Gen2. Current prop is Twister 14x21 stainless 3 blade with some slight damage (Nicks in two blades a little bigger than a pencil eraser) and a pair of Nauticus trim tabs. Boat is new to me and I have had it on the water a total of 5 times. I have noticed it takes way too long to come up on plane and it requires WOT to stay there. It’s even worse pulling a tube although it does eventually get there. It loses a lot of speed when turning. It feels sluggish, almost underpowered, and I am getting 4000 rpms at WOT and a max of 36mph ( this is with full tank and 2 adults, 2 small kids). There is a very slight vibration and is more noticeable at just above no wake speed. I have replaced fuel water separator, ran 2.5 tanks of fresh premium fuel through, thinking it could’ve had bad fuel. I am at a crossroads here in trying to chase an engine issue like plugs, wires etc…. Or trying a different prop. Can the little bit of damage on the prop cause this much of a performance issue? Maybe Its a combination of issues. Where would you guys start in diagnosing?
alldodge
Welcome
The slight ding on the prop should not cause low power or vibration. It's a new to you boat so need to do some things to figure out what the issue(s) are.
What is the motor serial number?
Your motor should be able to turn 4800 rpm at WOT. Right now we need to find out why it wont. Start with a compression test to find out if your running on all 8 cylinders the same. Can get a loaner gauge from several auto parts stores
If all cylinders are above 140 psi then good, great would be 150 psi
Premium gas will reduce the power your motor makes, need to run 87. The octane is not your issue but does add to it
Is the speed coming from the boat gauge? Not an issue right now but boat gauges may not be accurate
