2001 Merc 125hp only have idle no power
Bigdub18
Got a 2001 Mercury 125 2 stroke on my 2001 Starcraft pontoon. The boat starts up fine but when I put throttle to it I don’t have any more power than idle, 800rpm at full throttle is all I have. If you pump the fuel primer while driving I get a couple hundred more rpm. Not sure what’s wrong. Any thoughts??
alldodge
Is the linkage opening up the carbs?
If carbs are opening, then check compression
tommarvin
Ensign
Sounds like shes starved for gas ,if she goes faster if you squeeze the primer bulb.
You should remove the carbs ,watch all the you tube videos on carb cleaning/rebuilding maybe if you trash a gasket.
Then clean your carbs, idle jets work bu the high speed jets are plugged.
schematic
also check for spark at each plug. You may only be running on a few cylinders
