2001 Johnson Ocean Pro 175 Lower Unit
cckissam
I need some help/advice and would greatly appreciate any comments or feedback from those familiar with this problem. Apparently the lower gears and bearing set on many of the pre-Bomardier owned OMC motors have had major problems breaking. We were just at 100 hours on ours when she went bad this past weekend. Question is when we get it fixed are the replacement parts quality enough to really fix it as the concern is it's a Quality issue.<br /><br />Thanks and Regards,<br /><br />Christopher Kissam
Dhadley
Re: 2001 Johnson Ocean Pro 175 Lower Unit
The new Bombardier gears are fine. So are SOME aftermarket gear sets like the ones Pro Marine distributes. Your dealer can order either.<br /><br />Good luck!
cckissam
dHadley<br /><br />Thank you for the reply and I sure hope that we can get the quality we expect. I can only assume that my neighbor who had so many of the same problems was getting crap parts before they figured out what the real problem was
