2001 johnson lower unit output shaft seal
FLCRACKER
I have a 01 johnson 150 ob. after pulling the prop off I noticed wire leader wrapped around the output shaft between the shaft and seal. Can the output shaft be removed without dropping the lower unit or is it a major issue to replace this seal? Any help is greatly appreciated. Thanks :confused:
