2001 Johnson 150 Engine surges
jp8631
After a few minutes in higher rpm, my engine starts to bog down and the rpm's start surging. Engine idle is good and up to 1200 rpm, when I increase speed after a few minutes the trouble starts.I dont think its fuel related. Does any know what else it could be? It seems like its electrical, coil pack or stator?
Chris1956
Honorary Supreme Mariner
Pump the primer bulb at high RPM, to rule out fuel pump and fuel delivery issues.
SweetD
I had similar issues the end of last season, anything over fast idle speed would result in bogging/surging kind of intermittently. This spring I checked everything I could, and settled on something electrical. In the end I swapped out my ignition switch on the remote controls because even though it bench tested OK, it was sticky. I also switched out my battery lug nuts to nylock nuts. I think I had a loose connection but couldn't prove it because I had removed the batteries last fall for the off-season.
So check all of your connections, grounds, etc., for corrosion and tightness. Start with simple. Do you have a service manual for your motor and are you handy? The service manuals can be extremely helpful for troubleshooting.
Also, this guy has great videos on a wide variety of troubleshooting topics:
https://www.youtube.com/user/DangarMarine/videos
Dave
