2001 Ficht 175 dying under load problem
JimInVA
Hey guys, newbie here, my ficht just bogs down and dies when I go to open her up, idles fine, cruises along in the no wake zone fine, then bogs down when I hit it, eventually cuts off, I have to squeeze the bulb to get her back to the dock, I just replaced all fuel lines and filters (except the tiny ornery zip tied one at the engine, I couldn't get that clamp off to save my life) and the spark plugs (XC12PEPB Champions) I can't afford to take it to the man right now, any ideas/help would be greatly appreciated.
walleye seeker
Re: 2001 Ficht 175 dying under load problem
sounds like she is running out of fuel.
1. could be lift pump needs a rebuild
2.could be needle and seat in vapor canister leaking
3. could be low fuel pressure from the high output pump
4.could be sucking air somewhere between motor and tank
JimInVA
Thanx walleye seeker, I've been told lift pump rebuild kit by a couple of non-expert guessers, sounds like I'm gonna need to get a book and some parts, I'll let ya know if it works, rebuild kit looks like the cheapest place to start.
