chriscritchett
- Oct 24, 2010
- 6
I have a 2001 F9.9 MSHZ that's been idle for a long time (couple yrs) and I've got it mostly freshened up - new impeller, oil change, filters cleaned, new starter rope, disassembled the carb and cleaned it all out & replaced all the rubber bits - and it's starting easily now and peeing lots of water, but smoky as hell. It's at least as bad as running a 2-stroke, with mostly white, maybe bluish smoke. It doesn't stink like an oil-burning car would and it's not that blue, but it's definitely not steam.
I was hoping maybe letting it run for a bit would clear it out, but I've probably got a solid 20-30 minutes or more on it at high idle and it's not any better.
I checked the oil separator box today and cleaned some watery oil mixture out of there, and ran it again: still smoky, and the inside of the separator had traces of milky oil in it again after 5-10 minutes. The oil on the dipstick looks fine, and there's no trace of 'milkshake' foam on the fill cap.
Any expert opinions / advice would be most welcome. My novice guess would be leaky head gasket, but I don't want to dive into that if I don't have to, and can't really afford to just drop it off somewhere and hope for the best. Thanks very much.
