2001 df60 cmp code replaced sensor same code where next.
John Groover
Alarm code for cmp sensor. Replaced cmp sensor same alarm code still emitted. Any ideals where to go next to clear warning code.
99yam40
what is a cmp sensor?
did you clear the code and it came back in?
maybe there is a wiring/connection problem, not the sensor itself bad
tbswhaler
Hi John,
I had a similar problem this year and went through quite a process trying a few things including replacing to sensor with no luck. I ended up removing, wire wheeling, and reinstalling my cam gear and the problem went away. Technically I put a different cam gear on as I have a parts motor - but aside from the location of the notches they seemed identical. Problem has been gone ever since. FYI you need to run the motor to remove the code - if the problem is gone it will alarm with key on the first time, then clear up and shouldn't come back.
Mohawkmtrs
yam: it's automobilespeak (obd ii).
CMP = Camshaft Position Sensor
and is differentiated from
CKP = Crankshaft Position Sensor
I agree with you...it could be a CIRCUIT issue.
99yam40
thanks
CM stands for camshaft
and CK = crankshaft
makes some sense now
