2000 volvo 4.3L temp indicator and trim indicator?
rickksan
I have a 2000 four winns boat with analog indicators for the volvo penta SX 4.3L V6. having problems with temperature indicator not working always reads full cold unless sometimes after the boat has been sitting when started the goes to full hot then goes down to cold within 15 seconds, but normally always stays at full cold and never moves it does not run hot so I'm assuming it'ts an indication problem also no overtemp horn during normal running conditions operation and horn seems to work properly and sounds when engine is started. I've heard of engines running too cold is that a possiblity? <br />The other problem the trim indiator seems to be extemley erratic and inaccurate? Also is there a good shop manual sold fo the 2000' Volvo penta 4.3L sx
