Jeff Broussard
- Oct 23, 2011
- 1
I recently broke the shifting cable on my ProCraft. I have a hotfoot installed so I also have a spare throttle cable running from the control box to the motor and the spare cable is disconnected at the motor. Can I swap the throttle cable with the gear shift cable on the control box and motor? I'm also having one heck of a time getting to the control box. I've tried accessing it from under the dash and from the storage compartment behind the seat. So far I have only been able to get to 2 bolts. There are 6 bolts running through the shifter plate inside the boat. I know for certain that at least 3 have nuts on the back of them. It almost looks like you'd have to separate the hull just to get to the control box but surely this isn't the case. Need help on how to remove the control box.
