2000 johnson 90hp running problem (overheating?)
polar bear
The motor has been performing great on friday. Went to head home and after about three miles the engine slowed down and cut off. At first I felt it had run out of fuel. Was able to "baby"it over to marina and get 10 gallons and off I went, About a mile later it cut off again.Got it cranked but kept it at idle was able to "limp" across sound to landing. Here is my question, when ever I started to ''push' it up to 2500rpm the hot lite came on ( did not notice at first because of sun in eyes)so dropped idle back to 2000rpm and lite went out.I removed both thermostats and one was stuck open.Did that cause all the water flow to go thru one thermostat and by pass the other head causing my problem. The tell tale pees 6 ft so think water pump is fine.Does this motor have a cut back mood that would shut it down?Need to fix asap due to have to have boat back in water this thursday to get to a meeting .I will not have time to water test it before that ........scary ps I did kick up some mud leaving the landing and saw sand in holes on thremostat
jakedaawg
Compression test 1st. Post model number with results of compression test.
polar bear
Well unable to run compression test till tonite and dead line is tonite. It still runs VERY strong so feel not is not the issue. When loading it on trailer it had just as much power as when I got it . It would accelerate quick onto plane also before slowing down after a minute or two and the hot lite would come on. I own a garage and just dont understand the cooling system. I feel It is either fuel or if this 2000 johnson ecm will shut down if hot lite comes on as a fail safe .Maybe you can explain how compreesion could drop under a full load, I do understand the pressureizing of the crank case to charge cylinder.
jakedaawg
Slow system will engage if overheat detected.
cooling system is simple. Impeller in h20 pump, t-stats, poppets, that's about it. All clearly explained in the manual.
can you rest your hand on the top of the head? If not its time to service the cooling system. Start with impeller replacement. They get weak over time.
T-stats and the rest are a little trickier to get to on some, hence the model #.
I mentioned compression test because overheats cause piston and ring damage. No sense throwing good money/time after bad power head. Must be done.
