2000 Johnson 150 clunking in gear
tperalta
My 2000 Johnson 150 OceanPro started making a clunking noise in gear. In neutral, you do not hear the noise. When in gear, especially at about 1000 RPM's or more, the noise is apparent. It sounds like someone is inside the lower unit slapping the lower unit with a hammer. The frequency of the sound increases with the RPM.
Joe Reeves
Re: 2000 Johnson 150 clunking in gear
Fuzzy metal filings on the drain screw magnets (stuff that you could rub between your fingers with no ill effects) is a normal thing.<br /><br />However, if you find metal particles that would be described as metal shavings, chips, etc which would damage your fingers if rubbed between them, then that would indicate that gear teeth have chipped, a bearing has failed, something of that nature.<br /><br />If the clunking is a steady noise such as a rapid fire gun being fired constantly every second, I'd suspect the above problem.<br /><br />But..... if the clunking is rather a momentarily, every so often clunk, which jolts the transom somewhat, and gives the sensation that the engine is hitting something, I would suspect the following. Your post also states in not so many words that you shift into gear slowly which also makes me suspect the following.<br /><br />(Jumping Out Of Gear - Manual Type)<br />(J. Reeves)<br /> <br />This pertains to lower units on all OMC manual shift outboard engines, or any OMC engine with lower units defined as a Shift Assist or a Hydro Electric Shift unit which incorporates a "Shifter Clutch Dog".<br /> <br />Within the lower unit, splined to the prop shaft is what is most often referred to as a clutch dog, hereafter simply called dog. The dog has at least two lobes protruding from it on both ends, facing both forward and reverse gear. The forward and reverse gears also have lobes built into them near their center area. When the engine is running, in neutral, the gears are spinning constantly via the driveshaft being connected directly to the powerhead crankshaft, but the propeller does not turn due to the fact that the dog is centered between the two gears, and the dog lobes are not touching either of the gear lobes.<br /> <br />When the unit is put into either gear, shift linkages force the dog (and its lobes of course) to engage the lobes of the the gear. The lobes of the spinning gear grab the lobes of the dog, and since the dog is splined to the prop shaft, the propeller turns.<br /><br />The lobes of the dog and gears are percisely machined, most with right angled edges that could be installed in either direction, and some with angles slightly varied that must be installed in one direction only (one end only must face the propeller). Dogs that can be installed in one direction only, if reversed, even if the dog and both gears were new.... would jump out of gear almost immediately. Keep in mind that the lobes are percisely machined with sharp angles!<br /> <br />Due to improper adjustment or worn shift linkages, but usually due to improper slow shifting, those percisely machined sharp edges of the lobes become slightly rounded. Now, with those lobes rounded, as the rpms increase, the pressure of the gear lobes upon the dog lobes increases to a point whereas they are forced apart (jumping out of gear), and due (usually) to the shift cable keeping tension on the engines shift linkages..... the unit is forced back into gear giving one the sensation that the engine has hit something, and the cycle continues.<br /> <br />Some boaters have the mistaken belief that shifting slowly is taking it easy on all of the shifting components..... Wrong! Shifting slowly allows those percisely machined sharp edges of the dog and gears to click, clank, bang, slam against each other many times before they are finally forced into alignment with each other..... and this is what rounds those edges off! The proper way to shift is to snap the unit into gear as quickly as possible.
tperalta
I have not checked the lower unit oil since this started the other day. The clunk is not an every so often event. It is definitely rhythmic and momentary, at about 1000 RPM's the clunk may happen once every two or three seconds.
