2000 70HP LOWER UNIT
whofan
my oil in the lower unit keeps turning black. changed twice since new my dealer says that their is something wrong. in the shop now. Anybody have this problem?
OBJ
Re: 2000 70HP LOWER UNIT
Hi oberboat.....<br /><br />Well....if ya' use the rig heavy and you have only changed the lower unit gear lube only twice since 2000, then it ought to be black. Gear lube turns black from age. It will break down and overheat and turn black. If this is the case and you use the rig a lot, change the gear lube more often. If I'm wrong, please let me know. Thanks.
