Jld1983@att.net
- Apr 2, 2019
- 5
Hi, I have a 2000 Johnson 40 hp (J40RLSSM) that started running rough last summer. I was running the boat down the lake and it suddenly lost power. It never died just lost power to run over 5mph. After restarting it would take off again and run fine then after a few minutes do the same thing. I looked under the hood and the fuel pump was leaking a little so over the winter I rebuilt the fuel pump. Took it out this spring and it would open up for about 5 seconds and then lose power again. I can turn the motor off and fish for about 30 minutes, start it up and it’ll take off but only for a few seconds then lose power. I used a light to watch the fuel flow into the carbs when it started acting up and it seems to have no change with the motor acting up. I replaced the plugs, wires, and coil. I checked the compression 120 psi on both cylinders. Put a spark checker on it and have 7/16 spark on both cylinders. Was going to replace the power pack next but was hoping for some advice before I did that. Any help would be greatly appreciated.
