2000 150hp
Hillierwade
I have a 2000 150hp Johnson and its loosing fire on all cylinders after its running for 15 or 20 mins. Seems like when the engines cools completely off it will remain spark and start again. Anyone got any idea what could be wrong before I start replacing parts.
Chris1956
Honorary Supreme Mariner
Maybe you could use a hair dryer to heat the various components, while running it in a barrel or on a flusher. I would start with heating the powerpack. If the motor dies, it is likely the powerpack, since the balance of the motor will have the cool air on it. Next would be the optical sensor.
I would think the stator is last, as it should be the most heat-resistant.
