200 hp Saltwaterseries lift motor engaging on its own.
Mc Tool
If the trim switch seems sensitive ..... thats a good indicator that the switch is faulty and ,in this instance it shouldnt be to hard to prove .
I think the point others are trying to make is that .... well imagine that the harness to that switch is worn thru some distance from the switch and is grounding which is the actual fault . By removing and replacing the switch you inadvertently move the harness and the fault disappears........untill things "return to battery " ( settle back into normal position ) wire grounds and your back where you started .
Its not just a money thing , more about making it home .
I know an enthusiastic trim isnt likely to bring you down ( unless it does it while crossing a bar ). Thusly it is important to prove the fault , especially on something you cant walk home from.
I have just watched my neibour replace most of the ignition components on his quad because the kill switch wire had worn thru under a cable tie and was shorting on the handle bar :)
crazy charlie
Thanks,I pretty much confirmed it after a very close look yesterday.The switch is beyond sensitive.I only touched the switch without pressing it and it activated and wouldn't stop until I pressed it in the opposite direction.Unplugging it is an easy way to trouble shoot as previously mentioned which I have to do anyway. I just kinds like the idea of an easy and relatively cheap replacement I can do in 5 mins so why not do it anyway.Charlie
