Greetings,
I just won this boat.
http://cgi.govliquidation.com/auction/view?id=900845
I'll be doing quite a bit of cleanup and restro. Im thinking they painted over the Gel Coat on this but I havent even looked at it. If so Im guessing light sanding and then anti-foul paint would be best? I have zero experience with boats. I like the idea of coating the inside of the boat with bedliner since you can get those in different colors now.
As far as the engines go, what is the generally accepted mean run time before overhaul? The one motor has about 600 hours and Im guessing this is close to end of life? Apparently these Johnson 70HP are year 2000 according to the serial number. Thanks in advance..
Jackson
Jackson
