Re: 20" or 25" Shaft?
Thanks for replies...<br /><br />It's not a tri-hull, but kinda similar. looking at the back of the boat, the V hull is in the center with air channels on each side between the V hull and the left and right pontoons. The boat is all fiberglass and the left and right sides of the hull are flat bottomed. To give you a better idea, if you are familiar with the hulls that you could plug a wave runner into it to power it, thats what this is. I believe it was called a Whisper Craft, but not shure. When I bought it, I decided to build a V hull where the wave runner would go, mount an outboard to it and made a deck boat of it. 3 and half years later I'm done, looks great, but just need to get the power right...<br />The Johnson is a 25" shaft, and after eye balling it this mourning, saw that the cavitation plate is at least 4 " deeper than the bottom of the V hull...
