Re: 20 hp mariner need help
First of all welcome to iboats :welcome: good having you aboard...
I'm not sure I understand what you're saying about the spark. What is "Spark reserve is 1/2 or better"? Are you saying that the spark jumps a 1/2" gap? Do you have proper spark to both cylinders? And if so, is there gas getting to that lower cylinder? If that answer is yes to both questions, it should be running... Also what is reseting the reeds? Never heard anybody say that before either... Reeds are either working or not. They either open with vacuum and close with compression or they don't. So maybe a little clarification and some pictures would be great... One final thought, is this a single carb or two? If two carbs the carb feeding the lower section need attention...
