20 hp chrysler no high speed
gregory62
I have a 20 hp chrysler 19??<br />when in the garage in a garbage can the motor runs great, but out on the lake it won't give me high rpms. at best I can get high idle out of it. when there is a load on the engine, it won't rev up. I was thinking it might be something with the carb.<br />Thanks <br />Greg
eurolarva
Re: 20 hp chrysler no high speed
Hello Gregory. Great state you live in :D . It could be your carb or even a fuel pump or something wrong with your fuel line however I would test the compression first. This is also a symptom of a problem with the head. If you dont have a compression tester they cost about 30 bucks at sears. Pull the spark plugs out and see if both spark plugs looks kind of grimy and maybe have a slight oil residue on them. This would be a good sign. A bad sign will be one spark plug clean and the other dirty. Also post your model number. It should be on a small metal plate located under the carburator need the cowling lock.
gregory62
I cleaned the carb last night and sprayed carb cleaner where the spark plugs go. After I ran it again I checked the spark plugs, the top one was dirty, grimy like you said, the bottom one was clean. I will post the model number tomarrow, I have to go and check on it. Do I have a new anchor or can something be done?
eurolarva
Clean spark plug could mean a blown head gasket which is simple to fix. I would get a compression test done on it before dumping any money into and also test for spark. I live in brooklyn park so if you are close you can borrow my compression tester.
gregory62
Thanks for the offer on the compreesion tester, but I bought one last night. the top cylinder is at 105 and the bottom one is at 60. I tested the spark, and it seems to be good. The model number on it is 203HG. Does anyone know what year it is?
eurolarva
The 203HG motor was produced in 1975 and 1976. Compression number on number 2 is pretty bad. Hopefully it is just a head gasket. I tried searching for that head gasket and can not find one for a head going back that far.I believe the gasket for a 1978 20 HP will work on that motor and the mercury number is 27-F458527. A site I have had good luck finding gaskets is called the Shad Connection however there site is not loading tonight. I would pull the head cover off and see what kind of damage you can see. If the pistons are scored or damaged or the cylinders are scored I would agree with your first post about it being an anchor. If the piston and the cylinder look good maybe a head gasket is all you need.
gregory62
I pulled the head gasket off last night and it was blown. The pistons and cylinders looked good<br />so all I have to do is find a head gasket. Also one of the screws has a crack in it. Are they special screws? Aluminum? should I replace all the screws, or just the one that is bad.<br />Thanks for all your help.
eurolarva
That is good news gregory. You might want to go to www.chryslercrew.com and buy a downloadable parts manual for your motor. That will give you the chrysler part number for the head gasket so you can cross reference it to a newer availible head gasket. Check that screw with a magnet. I believe they are standard iron screws.
gregory62
Thank you for your help.<br />I found a gasket a will be buying new screws.<br />Hopefully that will be the end of the problems for a while.<br />Thank again<br />Greg
