2 stroke
bassin08
hi guys just found a evinrude 10 hp early 80's the owner say's it needs a primer pump and fuel line comes with a 6 gal tank asking $275 can i repair this or should i go to a mechanic? thanks for all the help
Vic.S
Re: 2 stroke
Early 80s, 10 Hp ?? or do you mean a 9.9 hp
What do you mean by priming pump. The fuel line bulb?
Fitting a new fuel line and bulb should be within the capabilities of most people.
Suggest you post the model number so that the exact model and year can be identified
If it is a 10hp then I think it will be a commercial model but the model number will tell
kenmyfam
Re: 2 stroke
I would be more concerned about the condition of the rest of it.
Fuel bulb and line is an off the shelf item.
jonesg
Re: 2 stroke
HE has to demonstrate it running.
At the very least a compression check.
You might be buying a $50 parts engine.
My 10HP needed new coils, points, condensor, plugs, plugwires and a water pump. But I paid $125. The seller couldn't demonstrate it running because it couldn't run.:)
bassin08
Re: 2 stroke
thanks for all the help,he said it was a 10hp i didn't know they made them i only see a 9.9 on outboards,i haven't seen the motor going tomorrow morning he said it needs a bulb and fuel line,he said it is a 2 cyl. plugs are new and overall he said it was clean.if this is all true it sounds good for $275 the only thing is i have a 15" transom he don't know if it's a short or long shaft,how can you tell?and what are good numbers for the compression test,i will follow up after i see it,thanks again for all the help i'm i newbie at this boating stuff but it's worth it when you catch a bunch of bass or walleyes,see ya john
Vic.S
Re: 2 stroke
Post the model number!
That will positively identify the exact model, year and HP. It should also tell us the shaft length.
However you can measure it to determine the shaft length.
From inside the transom clamp, where the top of the transom or bracket will be, measure to the cavitation plate above the prop. A standard shaft model will measure a bit more than 15" ( between 16 and 17). A long shaft model will be a bit more than 20"
See http://www.smalloutboards.com/shaft.htm for info about transom heights and shaft lengths
jonesg
Re: 2 stroke
Buy a cheap line with bulb, they're very cheap and you're going to need one anyway. If he has another excuse take a walk.
Its a parts engine unless proven to run.
