Re: 2-Stroke vs. 4-Stroke Torque Output
Appreciate all of the feedback! Just couldn't see how the 4-stroke could turn a 26in without having some serious low-end torque and don't see how any 115 could reach 67 MPH. Maybe that was a souped-up 115 because they pushed that 18-ft boat (bigger & heavier than my KW) to 67 MPH & had good hole shot too. The gear ratio on the 4-stroke is the same as the 2-stroke, so how could a 115 turn a 26 fast enough to get 67 MPH. The rev limit is 6000 on the 4-stroke vs. 5250 on the 2-stroke, but I'd think the 4-stroke would not have the horses to turn the prop much beyond 4800-5000 RPMs. I asked Merc if they would give me torque numbers for their 115 4-stroke, carburated 2-stroke, and Optimax. If they give those numbers, I'll post them. I know the tourque band is important too, but we'll see if they pony up any numbers--might be proprietary info. Props are funny too, how do you explain my engine running to 5450 with a stainless 20-in Laser 2 with vents, but only 5250 with the 19-in stainless without vents? I have read a lot about vent holes and based on that the vents should have no effect on top end, only hole shot. The hole-shot with the 20 in was terrible. The RPMs got up super fast, but the prop wasn't biting until the boat got to about 20 MPH, then the prop got a good bite and the boat took off. I know it's off the original topic, but thought it was pretty interesting. The boat "jumps" out of the water with the 19 in. Jerked two large slolam skiers out of the water--they both jumped right up. If my 2-stroke was as reliable as other Mercs I've been associated with, I'd stay with it.<br />What's the word on the street on the 115 Optimax? I see they changed from a V-6 to a 3 cylinder. Thanks again, Scott
