2 stroke versus 4 stroke power
Jim W
I have an 18 foot runabout powered with a Merc 115 6 cyl 2 stroke engine until it self destructed. Two different dealers are pushing 90 hp Honda, Yamaha, or Merc 4 stroke engines, stating they deliver as much at the prop as the Merc 115. Is this true or are they pushing the 4 stroke 90 because it's the largest they make? Bottom line: I want to pull two skiers with ease, which my Merc 115 did; what size engine do I need?
Capt DHD
Re: 2 stroke versus 4 stroke power
Hello;<br />Why not go with what you know works.<br />Ask the Dealers of these enormous, over weight, under performaning 4-strokes if they will refund your money if you are not 100% satisfied with "their" recomendation of the use of "your" money. Should seperate the boys out quickly.<br />The larger 4-strokes have a list of very favorable qualitys, although being a ski motor, may not be one of their best uses.<br />Each of the com****** you have mentioned offer a 2-stroke in the HP range you are interested in you should ask about them. <br />This is strickly my own oppinion but ultimately it is your wallet. Why not consider the motor you know will do the job. (and save a few bucks differance to boot)<br />Just thinking out loud.<br />Rob
