I have a 1999 Mercury 2 stroke 150 that I just had the power head re-built. After installing I am having trouble checking the timing. I had a mechanic help with the instatalition. We started the motor and put it in the water. The motor started easy and ran fair but because we had not checked the timing, I ask him to do so to make sure it was right. Cover says 4 degrees BTDC for idle and 20 degrees at high speed. When he hooked up his light, we could not see the marks anywhere close the the timing mark on the flywheel cover. They were showing up around 4" to the right of the mark and could not get it to change, they were not even in the opening in the cover. I thought maybe the marks were off for some reason, but when the #1 piston is at TDC the mark shows that. I can not believe that the motor would even run that much out of time. It would start as soon as you hit the key. When he checked the timing, he took all plugs out, used #1 plugs wire but did not ground any of the plug wires. Could this have made a difference? Can anyone help on this. I have invested quite a bit of money in this but hate to run it if it is this bad out of time for fear of damage. Thanks for any replies.
