2 Stroke doesnt smoke
I have a 1989 Mercury 100hp Outboard with a gravity fed oil injection system.<br />This is my first oil injected motor,it doesnt smoke like previous 2 strokes I have owned which required mixing the fuel and oil together manually. I know it is using oil because I need to add oil to the resevoir. Im just nervous because as a 2 cycle outboard owner I take comfort in seeing a small cloud of smoke behind the motor. Does an oil injector give a more precise mix of oil than manually mixed fuel? Is that why my motor does not smoke, because it is more precise in maintaining the proper balance of oil to fuel ratio. Can the oil injection system be adjusted to run richer,if so do I need to have it checked out? The motor runs great the way it is, I just dont want to blow it. Should I have it taken off and go back to manually mixing?<br />Thanks for the help
