Welcome to Iboats,
To start with, how old is that 25 HP horse, bought it new, second hand purchase, was it used at sea, was conveniently flushed after use ?
If engine dropped dead while heading back home and with lots of steam, where actually lots of steam, powerhead, peeing port or back middle leg port ? Did lower leg catched any thing, plastic, bag, debris etc that could have clogged all 3 lower water intakes and you weren't aware of this condition ? Is thermo shot ? remove it and check, clean or replace if heavily corrroded, salty.
If engine has experienced an overheat cond due to debris or thermo, will need to re torque current head gasket to specs, if with missing issues while boating specially at 3/4 to full wot, need a new head gasket torqued to 30 NM. Take advantage to clean all water passages from crak case and cylinder head as well. Engine will work and cool much better.
Happy Boating
