sprouticus1
- Feb 25, 2008
- 19
well hello again Iboats. It's almost springtime here again in southern BC, and once again I am in need of your help (had to start a new profile.....issues signing in).
So last August I parked the boat in the driveway, expecting to take it out the followaing weekend. As luck would have it....the boat sat till mid october, because every weekend had lousy weather. I finally took her out for the final cruise of the year in october, and then parked her for the winter. I had some un-expected issues the last time out. My starter solenoid wasn't engaging, and I had to by-pass it by shorting out 2 screwdrivers over the leads. This allowed the starter to kick in, and I had my girlfriend push in the key to engage the choke. the engine wouldn't start, and I then realized the solenoid that works the choke wasn't working either. I manually pushed the choke, and she fired up. I ran the boat for an hour or so with no problems, and then packed her away for the winter..expecting to be working on it in the spring.........which is almost upon us.
SO heres what I know. My engine is a 1992 90 HP evinrude. the controls are most likely from the 1977 70hp that was on my boat when I bought it. (I have the controls for the 90hp, but I prefered the controls that were already on the boat.) Turning the key off does shut the engine off, but you can not start it with the key alone......you need to by-pass the solenoid. I can see the one solenoid going.........it's happened before and I know it's an easy fix....but for the choke to go as well has stumped me. I was thinking it may either be a grounding issue, or perhaps the controls are the problem. Or perhaps it is the solenoids. I don't know where look first.
I have a couple of weeks at least (perhaps months) until I will be out on the water, so I was hoping the nice people on here could give me a few tips before I get started.
thanx for reading.
thanx for reading.
