LODI QUACKER
- Feb 23, 2009
- 55
Hello to all,
I have a couple of questions about this little boat I use for fishing.
1. The drain plug on this little Crestliner jon boat is in the bottom of the boat, its a srew in plug that is not in the lower transom but in the stern floor just behind the seat. Now, all of my other jons you could, while under way, drain the water from the boat by removing the plug. Can You drain while underway with this system?
2. While underway at wot or near WOT water comes in the boat from the sides and some seems to splash off the motor and into the boat, What can I do to stop this other than slow down?
Thanks,
sinkin in MO.
Thanks,
sinkin in MO.
