simon_canada
- Jun 14, 2005
- 26
Hey guys,<br /><br />Looking for a bit of insight here..<br />The boat is a '90 Doral TRX with a 110 Evinrude V4 on the back.<br /><br />Problem: Charging issue; After having the boat for about a week, the boat wouldn't start. Took it back to the marina, where they checked the power pack, etc. and decided it was the battery itself that was the issue. Replaced the power pack, no change, so reverted back to old one, then they changed the battery, and voila, it was up and running again. It was for about 7 weeks. (using it every weekend, about 10 runs a weekend), and then one day, it wouldn't start (too little power). Got a boost, and I was on my way. But it won't charge, the only way we get it to go, is by running an external power source.. otherwise voltage gets soo low, it won't run anything, nor trim the motor up and down.<br /><br />It's back at the marina (under goodwill) and he says it's the RECTIFIER that is the problem, and is replacing it. But that doesn't seem to make sense to me, as it drops consistently, and isn't holding, even when running..<br /><br />Any thoughts from anyone else?<br /><br /><br />Second, slightly offtopic question, was regarding the trim/prop, the dealer said he believed we were running the trim too high, as the paint was coming off the prop. We recently installed a stingray on the cavitation plate (which worked wonders for out of the hole and fuel economy, not to mention overall stability), but, am perplexed by his poor explanation as to saying we are running the trim too high... how is that taking the paint off, and how do we rectify this? The boat stays on plane very easily, and we only adjust the trim up to save on fuel, and hit higher speeds. Is it the speed that's doing it, or? Hopefully someone can please enlighten me!<br /><br />Thanks in advance guys, You are amazing!<br /><br /> -- Simon
