rather_be_boatin
- Jun 17, 2006
- 40
Hello, I'm having 2 issues with my boat (99 Maxum 2400SCR, 220hp merc 5.0 2bbl), the 1st is the oil gets very slightly hydrated after a few hours of run time. Not enough to make the dipstick level increase but noticable. Upon close inspection it seems to somehow be sucking moisture in through the valve cover breather hose that runs to the carb. Has anyone heard of this? Is there a cure? My 2nd problem is an erratic temp. guage, it will rise slow, drop fast, go all the way to 280 and down to 0 than hold steady for awhile, buzzer never buzzes and verification with a temp gun indicates steady t-stat housing temp, steady riser temp. Impeller, risers, manifolds, guage, & sender are all new. I'm not sure weather to trust the thing or not, I've put plenty of hours on with this problem but would like to solve it. I'm baffled. Thanks in advance for any help.
