Hi All<br /><br />Today I developed a power loss problem on my 2000 90hp yamaha 2 stroke. It happened quick - was idleing after a long run, went to give it gas and it seemed fuel starved. It will idle and run lower rpm's but that's it; no guts at all. I limped home, logged into iboats and after looking over the helpful info here, I have:<br /><br />1) tested compression - all good<br />2) checked spark - all showing spark<br />3) Removed carbs - removed bowl and top cap, sprayed with cleaner, all ports seems clear.<br />4) removed spark wires, one at a time, while idling and #2 is the culprit.<br /><br />Now what? Could the "Emergency starter valve" have something to do with it? Is it more likely something bad with the carb? Any other suggestions?<br /><br />Many thanks,<br />Bud
