2 cycle oil vs 30 weight
nomyar
Please help I'm new to the older model outboards. I have always used a 4 stroke but I just received from my wife grandfathers estate a 1954 QD-15 10 hp Johnson. I was able to tune it up and get it running, however I am wanting to know what fuel mix ratio should be used and if I should stay with the 2 cycle or use the 30 weight? Both are shown to be acceptable on the engine cover decal. What is best? and what mix ratio?
Thank You
nomyar
kenmyfam
Re: 2 cycle oil vs 30 weight
I always found in my 2 stroke motorcycle days that you had to give the tank a shake before each trip to re-mix the fuel with SAE-30
TCW-3 once mixed will stay mixed.
Silvertip
The issue with SAE30 is that it is a conventional motor oil. Two stroke oils are designed to "burn" more completely and are made specifically for two-stroke engines. There is also a difference between "two-stroke" oil and "TCW3" branded two stroke oil. TCW3 is for use in "water cooled" two strokes. Conventional two-stroke oil is designed for use in "air cooled" engines. So DO NOT use LawnBoy or other chain saw/weed whip oils in your water cooled outboard.
wbeaton
In spite of what is on the BRP site, the ratio is 24:1
