2-cycle oil question?
BoneDigger
My motor is a 2000 model 90 HP Mercury (Classic)<br /><br />Here's my question. I have nearly a gallon of Evinrude 2-cycle oil that's probably 4 years old. It has been in my garage so it has not been in the elements. It says that it is TC-W3 certified. Would this be OK to use in my Mercury? If it would not be safe, or if there is even a doubt, I will not use it. I appreciate any input.<br /><br />Todd
ZmOz
Re: 2-cycle oil question?
That will be fine. Oil doesn't go bad for a very long time.
LubeDude
Go for it, not a problem! Just dont tell it you are putting it in a Mercury.
quantumleap
Master Chief Petty Officer
Use it up then try a synthetic or synth. blend and see if you like the improvements. :cool:
LubeDude
Originally posted by Quantumleap:<br /> Use it up then try a synthetic or synth. blend and see if you like the improvements. :cool:
I thought that was my line? :D :D <br /><br />Good to se others starting to speak up about synthetics. :) :)
quantumleap
Well Lubbie, You got me there! I used to be skeptical but I made the switch to full synth. The smoother idle and GREATLY reduced smoke made a believer outta me! :cool: :cool: :cool:
