...Ok this may seem a bit odd but here goes.
I hitched up the boat today to take her down to the gas station to fill er 'up. Before I left the house I added a quart of 2 cycle oil, enough of oil added with 12 gallons of gas to make a 50:1 ratio. That was O.K
I made it down to the gas station and added 12 gallons of 93 octane, closed the cap, grabbed my receipt and off to the lake for a test run after some work done on the motor. (1971 115 hp Merc)
After I had the boat in the water I pumped the primer bulb and was watching the clear glass inline fuel filter...the gas entered and it was clear to a hazy color!
The question is...all of the gas I have ever mixed has been a bluish green tint...is this normal? maybe an odd brand of gas? I know it mixed well on the way to the lake on the trailer. Mind you I completely drained the tank the night before remade all of the fittings and new fuel lines/primer bulb.
Is this normal maybe? I was thinking of going back down with a gallon can and pre mix 1 gal and see the color? Or should I be going back to the gas station and having a few words?
It would seem odd for it not to mix.. Or am I just crazy
